ECOS mise à jour: 3.7.0
Messagepar jean-marie » 05 Avril 2014, 15:59
Quelqu'un a-t-il fait la mise à jour 3.7.0 ?
Si oui quels avantages amène-t-elle?
jean-marie
Message(s) : 34
Re: ECOS mise à jour: 3.7.0
Messagepar alain.trinquet » 05 Avril 2014, 18:16
Voir quelques éléments de réponse là :
viewtopic.php?f=15&t=3006
Messagepar papybricolo » 06 Avril 2014, 22:51
Voici la note d'accompagnement (en anglais)
Release Notes for Software 3.7.0 for ECoS 50200 / ECoS 50000 / Central Station Reloaded
New features
- Support for L.Net converter. You can find the user's manual under
http://www.esu.eu/download/betriebsanle ... /zubehoer/ (german language only at this time).
- New decoder profile for LokPilot V4.0 M4 decoder for usage under DCC. If you use this
decoder under M4, the automatic profile will be used.
Bugfixes and smaller changes:
- Optimized screen redraw to make the GUI a little faster
- Improved address assignement (matching) for all applications such as ECoSniffer, RailCom
Address Display, Locomotive categories in routes or L.Net converter: Thew new rules is as
follows: First, a locomotive having a sniffer address will be searched for. If no such
locomotive exists, a locomotive having the real address will be tried to find. This means
that in future, you don't need to have Sniffer addresses; you can use the real locomotive
addresses instead (if you set all sniffer addresses to "0"). Of course, for M4 locomotives,
you still need a sniffer address occasionally.
- ECoSDetectors will be showed with their names
- Fixed display of RailCom-enabled ports on ECoSDetector devices (before, even a ECoSDetector
Standard was shown as "RailCom" enabled).
- In the locomotive select screen, you can no longer create a locomotive with invalid
addresses
- Locomotive categories are initialized now.
- Locomotive categories removed from ECoSDetector Extension now.
- If you try to edit a consist and cancel the operation, ECoS should no longer crash.
- Fixed a display problem on the turntables
- When using a Märklin turntable, you can no longer select non-existing tracks
- The programming for a Märklin turntable works correctly again now.
- Fixed a display problem when using more than 32 s88 modules
- User defined locomotive pictures (icons) with embedded colour profile ( like used by
Gimp 8.2) do work correctly now.
- Fixed some errors on automatic detection on ECoSLink devices
Traduction "gogol"
Notes de publication pour Software 3.7.0 pour ECoS 50200 / 50000 ECoS / gare centrale Reloaded
nouvelles fonctionnalités
- Prise en charge de convertisseur de L.Net. Vous pouvez trouver le manuel de l’utilisateur sous
http://www.esu.eu/download/betriebsanle ... /zubehoer/ (langue allemande seulement à ce moment).
- Profil de décodeur pour New LokPilot V4.0 M4 pour l'utilisation sous DCC. Si vous utilisez cette
décodeur sous M4 , le profil automatique sera utilisé.
Corrections de bogues et de petites modifications :
- Écran optimisé redessiner pour faire l'interface graphique un peu plus vite
- Amélioration de assignement d'adresses ( correspondant) pour toutes les applications telles que ECoSniffer , RailCom
Affichage de l'adresse , les catégories de locomotive en routes ou convertisseur de L.Net : Thew nouvelles règles est que
suit : d'abord, une locomotive ayant une adresse de sniffer sera recherché . Si un tel
locomotive existe, une locomotive ayant l'adresse réelle sera jugé à trouver. ce moyen
qu'à l’avenir, vous n'avez pas besoin d'avoir des adresses Sniffer ; vous pouvez utiliser la véritable locomotive
adresses à la place (si vous définissez toutes les adresses renifleurs à "0" ) . Bien sûr, pour les locomotives M4,
Vous avez encore besoin d'une adresse de sniffer de temps en temps.
- ECoSDetectors seront montré avec leurs noms
- Correction de l'affichage des ports RailCom activé sur les appareils de ECoSDetector (avant, même un ECoSDetector
Norme a été présenté comme " RailCom " activé) .
- Dans l'écran de sélection locomotive, vous ne pouvez plus créer une locomotive invalide
adresses
- Les catégories de locomotives sont initialisés maintenant.
- Les catégories de locomotives retirées d’ECoSDetector Extension maintenant.
- Si vous essayez de modifier un composé et annuler l’opération, l'ECoS ne devrait plus se bloquer.
- Correction d'un problème d'affichage sur les platines
- Lorsque vous utilisez une plaque tournante Märklin, vous ne pouvez plus sélectionner des pistes non - existants
- La programmation d'un plateau tournant Märklin fonctionne à nouveau correctement maintenant.
- Correction d'un problème d'affichage lors de l'utilisation de plus de 32 modules s88
- Défini par l'utilisateur des images de locomotives (icônes) avec le profil de couleur intégré ( comme utilisé par
Gimp 8.2 ) ne fonctionne correctement maintenant .
- Correction de quelques erreurs lors de la détection automatique des dispositifs d’ECoSlink
Personnellement je fais toutes les mises à jour pour ne pas avoir de soucis avec les suivantes (sauf la nouvelle version 4-0 (qui est pour l'instant en version "beta"...(a moins qu’Eric ou Antoine nous donne leur impression..)
Confucius
Message(s) : 272
